I know this is the right place to ask my question and hope somebody will help me. So my question is how to install IOS 8 on Iphone 5. Please guide me step by step and also please let me know that if I install IOS 8 in Iphone 5 will it slow down? the thing is one of my friends said me that it may slow down after installing IOS 8. I'm really confused please help me.
Issues with instalingl IOS8 on Iphone 5?please help
This is because servers might be busy and not responding to your device. That`s why you are getting this problem. Try again sometime later and if you still have problem then re-boot your iPhone. Don`t use any third party app to update your phone. Update directly from app store for further details visit this link.
The Apple iPhone 5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on September 2012 measuring 123.8 x 58.6 x 7.6 millimeters and weighing 112 grams. It uses nano-SIM card and has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution.
iPhone 5
It supports multi-touch protected with Corning Gorilla Glass with oleophobic coating. It ships with iOS 6 upgradable to iOS 10.2 powered by Apple A6 chipset, 1.3 GHz Dual-Core Swift (ARM 7-based) processor, and PowerVR SGX 543MP3 (triple-core graphics) GPU. microSD is not supported. It runs on 1 GB DDR2 RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities.
The primary camera supports 8 megapixels with f/2.4, 33mm, LED flash, and autofocus featuring face detection, panorama, 1/3.2″ sensor size, 1.4 µm pixel size, HDR (photo), touch focus, and geo-tagging. It can record video in 1080p at 30 fps. The secondary camera supports 1.2 megapixels with f/2.4 and 35mm and can record video in 720p at 30 fps featuring FaceTime over Wi-Fi or Cellular and face detection.
It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support, Bluetooth 4.0 with A2DP and LE support, GPS with A-GPS and GLONASS support, and USB 2.0 reversible connector. It doesn’t have stereo FM radio. It has built-in accelerometer, proximity, compass, and gyro sensors. The preinstalled Safari web browser supports HTML5.
Java is not supported. It runs on non-removable 5.45 Wh Li-Po 1440 mAh battery with standby time up to 225 hours both on 2G and 3G. Talk time is up to 8 hours both on 2G and 3G. It is available in black/slate and white/silver colors. When updating the iOS version of your phone, it will always update to the latest possible version supported by your device.
Since iOS 10 is already out and your phone can be updated until iOS 10.2, your phone will update to this version by default instead of iOS 8. For a more stable updating of your phone, update it using a computer. Start iTunes then connect your phone to your computer using the USB cable that came with it.
Select your device in iTunes then click “General” or “Settings” and then click “Check for Update”. Click “Download and Update” then enter your passcode when you are prompted.
1....
