Issues in message news and Dxsetup.exe
 Hi experts.
I am seeing this same error message once, perhaps twice in the 2 or 3 months. Also, I have a Missing or corrupted DxSetup.exe problem.
When I tried to install non-essential software programs, this same DxSetup.exe error message occurred. Message is: “Installation failed. Missing or corrupted DxSetup.exe.” I choose to terminate the installation and delete the non-essential software program when the error message window popped up.
Please help. Thanks.
Answered By 0 points N/A #92456
Hi. The picture showing that the software you are using has some missing file and that's why this software is not working properly and the real issue is backup of your software so you need to replace the backup of the software and then install this software again and the software will working properly. So the issue is with your software backup and then installs this software again with the new backup and this solution will resolve for you. Hope this solution will help your getting out of the problem. Otherwise you are not getting to solve this solution so you need to replace the backup of this software.
