Issues with my systems hardware configuration
20 points
Posted on - 08/07/2012
Hi all,
Definitely, it is something wrong with my systems hardware configuration.
Error – "07/14 03:59:38 rsync: get_xattr_names: llistxattr("/Volumes/OWC Mercury Elite AL Pro /.",1024) failed: Resource busy (16)"
When CCC tries to change on the target, it receives that similar "Resource busy" error message.
Usually, that error shows that the hardware isn't working. So maybe, it happens in a bad port, bad cable, failing disk or bad enclosures.
I need to solve it. Please help.
Thanks a lot.
