Aimee Heart
Posted on - 07/23/2019
After performing a Windows update, I receive the following error message while you work. “The purpose of the nextafter procedure entry could not be set in the MSVCR120_CLR0400.dll dynamic-link library.” What does this mean and how are we going to solve it, and currently I realize that Skype for Business search does not find anything either.
Issues Of Msvcr120_clr0400 Dll
There does not seem to be any “multiple causes” for the error message. There is an explanation for the error message. The following means: Scan your system for MSVCR120_CLR0400.dll and check properties after noticing Whatever the version, write it, return it and tell us what it is. The files are stored with the C ++ 2013 redistributable package and are not part of a Windows installation.
Therefore, it is not certain that sfc / scannow can help you. These DLLs are running, and even in Protestant programs, you are told that they can not find the nextafterf function in the MSVCR120_CLR0400.dll file, as you can see on my system with the version I just typed from the file It seems that your MSVCR120_CLR0400.dll file has been affected, that is an incorrect version or that something else is wrong.
But as usual, we do not know anything about your environment … Are you a particular user, a business user connected to a corporate network or something else? There may be a reason why you have this version of MSVCR120_CLR0400.dll on your system. First, create a system recovery goal to undo changes if the situation gets worse. Restart your system after uninstallation and publish it, even if there are many completely different errors.
