Hello fellows,
It is all about recovery excel shortcuts file. How can I be able to recover those excel short cut corrupted files in my computer with an operating system of Windows XP. I am bothered and really disappointed about what happened yesterday. I hope there is still a chance to recover those files.
Stephen Heris
Hi Stephen,
IÂ searched a solution for you it may help you solve your problem.
Firstly open a new excel workbook.
Click the Office tab button and click on open to see the files of excel.
Locate the excel File you want to repair, do drop down of Open so that you can see the Open and repair.
Hope this helps your problem.
lee hung
75 points
Stephen,
Thank you for your inquiry. There is a tool that can assist you in recovering your corrupted files. This tool is called "File Repair". The nice thing about it is that it is very simple and free to use. To download this go to: http://www.filerepair1.com/. Once you have downloaded the program enter the file that is corrupt and click on start. The program will then begin its work, just make sure you have entered the full file source so it can find the file.
