It Displays 0xc19001e2 Error While Downloading Windows OS
With reference to Windows OS, Explain the 0xc19001e2 error code briefly and show the steps to fix this error code, and add the snapshot of the error.
Installation error named as 0xc190001e2 error code that occurs when a preinstall script fails to execute or return an error. The message for this error is MOSETUP_E_PREINSTALL_SCRIPT_FAILED. The user has to reset the Windows Update Components to resolve this error code and the steps to do this process are as follows:
Step 1: Install the Windows Update Troubleshooter.
Step 2: Open the file and select the Windows Update option.
Step 3: Click on the Advanced option.
Step 4: Select ‘Run as administrator.’
Step 5: Select Windows Update again then click on Next option.
Step 6: Wait for the process to complete and close the window.
Step 7: Repeat the process again and select the second option from the Windows Network Diagnostics list -> click Next.
Step 8: Restart the system and check for the error again.
Upgrade Using ISO File.
Step 1: Locate the ISO file and open the file then mount it. Restart the System.
Step 2: Open the File Explorer and locate the DVD drive then click on setup.exe file.
Step 3: Give the UAC permissions by clicking on Yes option.
Step 4: Continue and accept the Microsoft License Agreement by clicking Accept.
