It Displays 800b001 Error While Activating Windows OS
Concerning Windows OS, Explain the 800b001 error code briefly and show the steps to fix this error code, and add the snapshot of the error.
The Error Code 800b001 is a Windows 10 activation error that occurs when the system upgrades from older Windows to Windows 10. It is not a critical system error that affects the ability to install or activate the operating system. Some ways to resolve the error code are as follows:
Solution 1:
Remove files from the Download folder.
Go to the directed location C:\Windows\SoftwareDistribution\Download and remove the content from there, then click on the Activation button again and again and check for the error is resolved or not.
Solution 2:
Disable the firewall and VPN
