It Displays 80190194 Error While Installing Windows XP
Concerning Windows OS, Explain the 80190194-error code briefly and show the steps to fix this error code, and add the snapshot of the error.
When the user cleans the installation process on the computer OEM CD of windows XP with a service pack or home or professional, and after installing all the hardware driver, it might give an error named as 80190194 error. The error stops the installation process, and the process to fix the error code are as follows:
Method 1:
Manual Update.
Step 1: Log-in as an administrator on the computer.
Step 2: Go to Start >> All Programs >> Accessories >> System Tools.
Step 3: Select the ‘Restore my computer to an earlier time’ and click on Next.
Step 4: Click on the restore point list, then click on Next.
Step 5: Click Next on the confirmation windows.
Restart the computer after the completion of the task.
Method 2:
Novice Computer User Solution.
Download the repair utility. Click on Scan after installing the program, and when the scan is finished, then press the fix error button. Restart the computer now.
