Is it good to install msnbc.com App?
Is it good to install msnbc.com news related application for iPhone?
Will it make my iPhone to produce slow performance ?
Or any other problems will it cause?
Installing msnbc.com actually is neither good nor bad. It would not cause your iPhone to produce slow performance. It would actually depend on the need of the user. Talking about the application itself, it is currently soaring in popularity to consumers and advertisers because it offers outstanding news and lifestyle content for consumers and advertising opportunities for advertisers.Â
If you try to read reviews about this application you would actually get a fair number of good and bad feedbacks. I would suggest that you read the reviews, download it and give it a try so you yourself would get the experience. Anyway it is for free. So it boils down to one point that the use of this application would depend on you.
On the technical side, msnbc.com is an interactive application and needs updating regularly to get up to date news so this would mean it also needs internet connection all the time. That would be WiFi and/or 3G.
Applications that use a lot of 3G tends to consume a lot of battery life and which obviously makes your iPhones' battery life shorter. You can also use it conserving battery life by putting off your iPhones' 3G so you would only use when needed. This is the only downside of using an interactive application.
