Good day to all, why is that after I reinstalled the apps It got my opera mini dns error while opening it through wifi connection? Anyone here had experience the same problem when reinstalling opera mini from higher version to lower version?
It got my opera mini dns error after reinstalling from higher to lower version
Dear Canyon,
since while reinstalling all your apps, the opera mini also got installed fresh, it has lost its previous working settings, user preferences and network settings. If you are using opera mini on a data plan then you just need to call your network provider's helpline (or stop by their store) and ask them to resend the data plan settings once more to your phone via text.
Once you set them back your opera mini will not give the error.
Hope this solves the issue.
Regards
