Is it necessary to downlaod free iFinger licensed key after drive format?
If I format my drive then do I have to download the free ifinger licensed key again for installation of the software?
Hello Kurt,
That will depend on the type of license you have for the iFinger application. Some licenses are meant to be used only one time, and if it is that kind of license that you have for the iFinger application then you will not be able to use it after you format your drive. So you will need to check that first.
But some licenses restrict their usage to only a single PC. If you used it on the computer that you
want to format right now then you cannot be able to use it on a different computer. For that, there is no problem with formatting the drive.
But some licenses do not have any restrictions at all.
Carl
