Is it necessary to install 7 zip?
Once you have a compress file then you must need to decompress it. Some files are being compressed because they contain too much memory and that why they cannot be Handel easily. So for this purpose a compression is used to compress these kind of files. Once these files are compressed then to use them you must need to decompress them. In your case study it looks like you have files that are compressed by using 7 zip so you need to install 7 zip to decompress these files to run on to your computer. This will insure file security and will be easy to use also. So you will be happy with your game. I hope this will help you a lot in solving your problem.
7 zip is one of the best and fastest open-source compressing program I have ever used. It can be used to open not only supported file formats, but also many files that can't be done with any software. Also, its shell extension is clean and nice to use. There are many file formats especially .7z is a popular compressing format with highly compressing ratio.
If you don't like 7 zip, you can try the programs listed in this article.
Notifications
