It is noising and working slowly. What should I do?
When I press the power button of my Pc, it makes noise. I am sure the source of this noise is Hard Disk Drive. Now my pc is working slowly from the startup. What should I do?
Are you sure, the source of noise is you HDD? Cooling fan cam makes noise sometime. If the source is HDD I am sorry to say, your HDD is going to die. You only can change your Hard Disk Drive. Some suggestions for you:
1. Create a backup before changing your Hard Disk Drive.
2. If your Pc is under warranty, send it for repairing.
3. If warranty is over, then buy one and replace. Â
Hi Mitu
There are two possible solutions to your problem. Either you change your Hard disk drive or you repair your hard disk.
There is a software, a diver booster that boosts a hard disk drive. It is packed along with Advanced system care. It scans your PC and fix any errors and it has two modes, game mode and work mode.
