Is it ok to bring my HP c302 laptop interview questions for my presentation in class instead of a projector? I find it more comfortable to use Microsoft Office Photo Manager 2010 for the customizable slide show instead of the manual slide show of a projector. I need the proper etiquette in presentations. Thanks.
Is it ok to bring laptop interview questions for my presentation?
It is okay to bring your laptop to the presentation provided you will project your material on the big screen for your audience. The base line evaluation for a good presentation is efficient was the information put across to the audience. Doing a presentation using Microsoft Office Photo Manager 2010 serves no harm provided consistency in the flow of information is maintained
If you are more comfortable using your own laptop rather than copying your presentation and using another workstation, it would be up to you. I assume that you can have a projector or other display devices available in your class which you can use for your presentation. Although it would be inappropriate to only use your laptop screen as a display for your presentation because people farther away from your laptop might not see the things you present.
