Is the application having the temporary files stored on my hard disk. And it also slows down the speed of the system. And the most important thing that It is safe to delete the temporary file as my I contain some important data. And if it is safe where I can find the temporary files.
Is it ok to delete temp files
Yes, near about every application have temporary files which is stored in your hard disk with the folder name temp. And it is safe to delete the temporary files if you do not have unsaved data. As for me, I delete my temp files, but it never creates a problem for me. You can find your temporary files by going into the run and typing %temp% and you will get all the temporary files in your system. You can also check from there how much space they have eaten of your hard disk. And you can also remove those all the files by selecting all and then deleting them.
