Is it ok if I copy software?
Hi techyv,
Is it ok if I copy software? I want to copy software from my friends laptop. Is it just fine if I borrow his software and install it to my computer? Thanks.
Hi techyv,
It is perfectly in order to copy a software program from one computer system to another and can be done by using a flash drive, a memory stick or a blank CD-R. Use the following process to transfer programs to your laptop;
Copying software from anybody is fine as long as it is free or it is freeware or shareware. Freeware is a program offered at no cost and available for downloading. Freeware is different from free software. With freeware, the program may be copyrighted and cannot be modified but can be used free of charge. With free software, the program is absolutely free.
You can modify it, redistribute it, and use it for free. But when redistributing a version of the free software, the original terms of free use, distribution, and modification must be included. On the other hand, a shareware is a consumer program in trial version. Shareware are sometimes offered as fully-functioning programs with all features activated just like what a registered version offers.
But the program works only for a specified amount time or what they call the trial period. When the trial period expires, the program stops working and you have to purchase it to continue using it. The shortest trial period I’ve seen so far is 15 days and the longest is 30 days.
If the program you want to copy requires a license, check with the original owner first if the license covers installation on other computers. Sometimes a license covers up to 2 computers. If the program you want to copy has or requires a license that means the owner purchased the software.
