Is it possible to add extra RAM on Samsung DP700A3B-A01US All-in-one PC?
I've a Samsung All In One DP700A3B-A01US PC. The PC becomes slow when I do high quality works. So I want to increase my RAM which is now 2GB and want to extend it to 4GB. The PC is too slim so I dare if it is possible or not. Any idea that it is possible to add an extra RAM in Motherboard Samsung Electronics Company's All In One PC?
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #161234
Hi Bm.lava,
You can add more if you want to, because that PC can support even up to 6 GB of additional memory. But you may try first to defrag your system because most of the time our PC became slower if we have too much defragment files. You can do it by selecting your computer, right click your hard drive then properties and select defragment now. Other cause is too many programs running in the background.
Answered By 10 points N/A #161235
Before adding extra RAM you need to delete some files and some software’s which you installs but you did not use that. That can be the problem. If you want to add extra RAM then you can add that. You need to follow 8 steps and then all the process will be complete. You will find all the steps in this website.
Thank you.
Answered By 0 points N/A #161236
Samsung DP700A3B – A01US All-in-One Desktop comes with 6GB DDR3 memory already. So if your computer comes with 4GB only, I think you can still be able to expand your RAM up to 6GB. And yes it is slim but you can purchase a memory from the Samsung store to ensure that you can purchase one that is compatible with your computer system.
