Is it possible to connect growl Windows VBS to COM?
Hi there! I just wanted to know if it is possible to connect it on COM. I am currently using a Growl Windows VBS for instructions on VB shell script. Thanks for the answer.
Hello there !!
Yes, ofcourse you can use the growl windows VBS to connect it to the ROM. And also you can use the VB shell script for doing the same. So don't worry just try to use it, it will get connected. Also i am providing you with the web address for downloading the Growl for windows so that you feel convenient in making the download easily.
1. http://www.softpedia.com/dyn-postdownload.php?p=9169&t=0&i=1 (this is the genuine website for PC software)
Just open the given address and you will get the download link, just hit the enter key or the mouse button to start the download.
