Is It Possible To Convert A Word Doc To A Jpeg?
Asked By 25 points N/A Posted on -
I want to add a graphic that I have created in aword to jpeg to add it into PowerPoint for my presentations. Can I convert a word doc to a jpeg so that it will be easy to store it in any other place also?
Answered By 50 points N/A #103691
It is possible to convert it to a jpeg file using the paint inbuilt in every Windows system. All you have to do is follow the given steps.
Step 1: Open the document from which you need to copy the graphic by selecting that graphic and then pressing Ctrl + C.
Step 2: Open a new paint Windows and press Ctrl + V to paste it to the screen.
Step 3: Now you can click on save button on paint and save it on paint using the jpeg format.  
