Is it possible to create teaching material swf?
Hi guys,
Is it possible to create teaching material swf? Using swish max application is not that easy, I would like to attract my students in my presentation using moving animated letters during the discussion to catch their attention. I know you can help me.
Expecting some help, thank you.
Answered By 0 points N/A #182097
Friend !
why you do not try to make presentation using animoto.com ? you can make as much animations as you need for your  students and you will not need to buy any software to do this. i did make personally many tracks , and my students did like them very much.
So when you made it, you can download those tracks/animation as SWF, and also you can play them in window media player and flash player as well.
