Hi guys, I want to create a template using HTML for my blog as I only know HTML programming and working with it but the problem is I don't know that is it possible to create a template using HTMl or not as I never heard about this before so please tell me can I create a template using HTML?
Is it possible to create template using HTML?
Hello, yes it is possible to create template using HTML but it is recommended to create the template using other programming languages like CSS it is much recommendable because you can create more interactive and best user attractive templates in CSS format when compared to HTML. Please use one which offers more options which makes your website much user attractive. Thanks
