Is it possible to digitize the Doodles into Adobe’s Apps?
I would like to get my sketches, doodles, and brainstorms into Adobe Photoshop or Illustrator. I also want to share concepts or other hand-drawn images with my friends and colleagues. Is there any app which can digitize the Doodles into Adobe's Apps? Can anyone suggest me suitable app for me?
Answered By 590495 points N/A #131744
If you simply want to load or open your sketches or doodles into Adobe Photoshop or Adobe Illustrator, you can scan your drawings or sketches using a flatbed scanner and then save the scanned image as JPG or PDF or any file format that is supported by Adobe Photoshop. Once the sketches are digitized and now saved in a file, it is now easy for you to load it in Adobe Photoshop and do whatever editing you want.
To digitize your sketches, you only need a flatbed scanner and an OCR software. If you already have a flatbed scanner, you can download ABBYY FineReader OCR Software. Simply install it on your computer and then connect your scanner to your computer. The software will automatically detect the scanner. If it doesn’t, select the scanner from the software manually and then apply it.
