Is it possible to draw on live msn 2011?
Does the 2011 live MSN feature includes the drawing tools and features? Or we have to download other software or plugins before the live msn adapts it in the application? I need your opinions and suggestions regarding this matter. More power experts.
Answered By 10 points N/A #153854
Yes, the 2011 live MSN feature includes the drawing tools and features.
When you are chatting with a contact of yours, you will find few buttons on the toolbar above the text box in which you type a message.
In the toolbar you will find a button which shows a pencil, click on that button.
This is the drawing tool which allows you to draw anything you want in the text box space.
If you want to change the color of the pencil you can select the color from the color tool.
See the picture below which shows the buttons.
Drawing Tools
If you have any picture already saved on your computer, you can just send it as an attachment.
You can also draw a picture in Paint and send it as an attachment if you feel that the drawing tool for MSN live is inadequate.
Hope this information helps you.
