I am having trouble editing my blogger site. I want to make adjustments but the editor in blogger won't allow me or just comes out with an error. Is it possible to edit the whole HTML of blogger with dreamweaver? Can someone give me tips on how to do this?
sibabu
5 points
Is it possible to edit my blogger site with Dreamweaver?
Hi jimmy
You ask a question about Html page create by DreamWeaver. Yes! DreamWeaver supports you to edit your page. But if you have enough knowledge about HTML code then it is better to leave your apps. I have a experience to use it. Windows 7 Windows Xp must perform about it. But i do not have knowledge about Windows Vista.
Though Dreamweaver is very good for page developing and edit, you may good to use manual system.
Well before you use it you may face some problems. now i am telling you…
In blog if you already submitted posts then at first keep your posts in safe.
Essential videos, images and links will be very important so make a decision to edit where you go.
You can try it.
thanks.
YES you can! Try to download an existing blog template from a site like blogger-templates.blogspot.com  and amend it in Dreamweaver. And you also need to have knowledge and experience in CSS. And in some cases javascript to really spice up your pages.
Yes, possible to edit your blogger site with the Dream Weaver this follow instruction below:
• Go to your Blogger account and then enter your account
• Then choice the Blog
• and then click the Lay-out
• Below the Lay-out Tab
• Look the Page Elements
• Select Fonts and Colors
• Then simply Edit the HTML
• Select a new template
• Click the HTML to edit
• You can see the Download Full Template, just simply click
• Save the Template in your Folder
Now open the Dream Weaver and after that open the Template file from the folder. Look the file you Save and then make sure that you remember the name of the file that you save from the folder.Â
