I have an iPhone 5s which I use for gaming, internet browsing, and watching videos. The only problem is, it's battery life is really terrible. I could only use it for around half a day before I need to charge it again. Is there anyway in which I could extend the battery life?
Is it possible to extend my Iphone’s baterry life?
You have to learn to preserve the battery. There are few tips you can use to improve the battery life.
1. Reduce screen brightness: Always keep the brightness at low level or you can keep it to auto brightness.
2. Turn off the data when not required, one of the reasons of sucking out battery life from iPhone.
3. Reduce screen lock-time for screen.
4. Turn off Push notification.
If you find all these insufficient for your iPhone battery, buy an extended life battery.
Scurlock Ward
