Is it possible to have 2 video card and RAM?
Hi IT People,
Is it possible to have 2 video card or RAM in a PC? because i have 1gb i want to make it 2gb.
Hi IT People,
Yes you can use two video cards in all cases as you require. If your Motherboard does not support any card then you can buy a external video card. Just plug it to your USB drive and you will go through your work it is easy and safe. Also you can use it with another PC so it is easy to install also. You can also use multiple rams in your PC. See the USB slots in your PC and buy one that full fills your requirements. You can buy one that best suits your requirement. You can then plug it to your computer and you will be done with your requirement. Also if you are not a computer technician then you can use this way to solve your problem. You can buy a external video card and RAM to solve your problem. If you require a built in card then it is also available and you can check it from your next door computer shop. I hope you are now able to solve your problem. Â
