I am using Samsung wave-3 but it does not have android app store as it has bada OS. I want to install android in my phone. There are many blogs over internet showing that it is possible but I am not able to do this. Is it even possible? I also want to know is there any possibility of phone getting dead? Please suggest some way to do this is safe manner so that my phone does not dead.
Is it possible to have android OS in my Samsung wave-3.
Yes, it is possible to install Android on your Samsung S8600 Wave 3 Smartphone but don’t expect that it is the latest version. The Samsung S8600 Wave 3 handset runs on Bada 2.0 which is Samsung’s proprietary operating system. So generally, it doesn’t run on Android in the first place. You can install Android 2.0 XXLD1 [S8600XXLD1] on your Samsung S8600 Wave 3 and here’s how.
To begin, download Android 2.0 XXLD1 [S8600XXLD1] on your computer. After that, you need to download Odin 3.09 to be able to install S8600XXLD1. After that, put your mobile phone in download mode. Turn off your Samsung S8600 Wave 3 and then press the volume down and Home buttons simultaneously. While doing these, press the Power button.
When you see an alert message on the screen to put it into download mode, press the volume up button. Unpack Odin then start the program. Connect your phone to your computer using the USB cable. A message will appear at the bottom left corner of Odin after connecting your handset.
Next, unpack Android 2.0 XXLD1 [S8600XXLD1] in a folder. Once unpacked, in Odin, press AP and then select the “.tar.md5” file from the Android 2.0 XXLD1 [S8600XXLD1] folder. Select Auto-reboot from the option and then press Start. After this, you have to wait until your phone is restarted automatically. When it is finished, it will now be running on Android 2.0 S8600XXLD1.
