Is it possible to install adobe flash in 64-bit?
I was trying to install Adobe Flash in 64 bit, but there’s an error that is always appearing.
It says "Unable to register DLL/OCX: RegSvr32 failed with exit code 0x5.".
Is there someone who can help me on how can I do this? I will really appreciate your help.
Thanks a lot.
Setup – Office Tab
Installing
      Please wait while Setup installs Office Tab on your computer.
Repairing files..
Error
C:Program Files (x86)DestongOffice TabExcelTab.dll
Unable to register the DLL/OCX:RegSwr32 failed with exit code 0x5.
Click Retry to try again, Ignore to Proceed anyway (not recommended),
or Abort to cancel installation.
                                                Abort          Retry         Ignore
Best Answer by Davidson Mudge
Answered By 0 points N/A #162962
Adobe Flash can be installed in 34-bit or in 64-bit operating system. If you are experiencing difficulty there could be any damage files in your system that hinders the installation of adobe flash. Run system file checker and use the command /scan now switch.
It will scan vital Windows files on your system and will repair the necessary damage files. Restart your computer then try to install again Adobe Flash into your system.
Answered By 0 points N/A #162963
Hi Techyvman,
       You can try these following solutions:
  • This can be caused by UAC problem, this means that you have to run the installer with elevated access or in Windows administrator with full access. If running Windows admin rights did not work try to turn it off from the control panel and then restart the computer.
  • If that fails and then installer works on another computer try to run a scan on the computer to check for windows files corruption. Type in SFC /scannow from an elevated command prompt.
