How to make my RAM always available for use?
Hi fellows,
I have a problem in recent times. Sometimes my PC shutdown or sometimes it may be slow due to the inactivity of RAM.
Whenever I open up the RAM & readjust it again, the PC starts working again for a certain days.
I just want to know whether there is any software or system to keep the RAM ever active?
Thanks!
Answered By 0 points N/A #126371
Hello there.
With my earlier PC I had similar problems where I needed to make sure my ram is always available for use. I would recommend you use "Advanced System Care 4" which has a free version and will not only free up your ram but also has other utilities to make sure that your PC is running smoothly. Just go to https://www.iobit.com/en/advancedsystemcarefree.php, download the free version and install it.
After the installation do the following to maximize the utility of your ram:
1. Run Advanced System Care 4
2. Click Toolbox -> Optimize -> Smart Ram -> Settings
3. Make sure the option "Run at Windows Startup" is clicked.
4. Click OK and then Minimize
So every time you start your windows this little freeware will work in your background (you can access from your taskbar) to make sure your ram is available for use.
Good Luck!
Answered By 590495 points N/A #316735
If your computer doesn’t start sometimes and you think the problem is with the memory modules, try reseating the modules or swap them. Turn off or shut down your computer then open the CPU case. Next, remove the memory modules from their slots. Now, get a pencil eraser then rub it on the module’s gold-colored pins and do it on both sides.
When you are finished, wipe the sides of the pins with a dry clean cloth. Do this on the other memory modules. When you are done on all the modules, reseat the memory modules on the memory slots. This should allow the system to detect the modules properly and fix the problem.
