Lisa Larsen
Posted on - 03/27/2013
Hi friends,
I need your advices for one more time. I have bought a bold 9900 phone couple of weeks ago. Now I want to get updated to blackberry 10 operating system. Is it possible to get blackberry 10 on 9900? If it is possible, how can I do this? I want to know the whole process of it. Should I update my phone to blackberry 10? Will there be any other problem? Please give your advices guys.
Is it possible to make blackberry 10 on 9900 phone?
Greetings Lisa Larsen,
A very simple answer would be No. No, you just can't update your BlackBerry Bold 9900 to OS 10. OS 10 is made for new generation mobiles which doesn't support your phone.
I hope this helped you,
Regards.
Lisa Larsen,
Blackberry 10 operating system, is made exclusively for the Blackberry Z10 mobile device.
Therefore you wont be able to update your model to BB10. You can however check your current software version, for which regular updates are made available by RIM. Check with you mobile operator, even when running 7.0 software, just upgrading to 7.1 makes a huge difference on the device.
Hope this helps
Regards.
