Hi and good day to all of you!
I have Minitab 16. We know Minitab is a statistical package that was developed by B. Ryan, T. Ryan and B. Joiner at Pennsylvania State University. After knowing its creator and its uses. I have downloaded it for a free trial of 30 – days. Now the trial period was ending near, I was thinking to buy the license of it for full version. So guys, does Minitab Transfer License available? Thank you and good day!
Is it possible to minitab transfer license?
Hi ,
The move license feature allows a single user license to move from one machine to another without contacting any customer care. This feature deactivates the license at current machine and generate a new product key to be used in the new machine. But the Move license feature cannot be used if you satisfy any of the following criertia.
· You purchased an academic (OnTheHub.com) License
· You purchased a Timed or Fixed Duration License
· You activated the software using the Web Activation method
· This feature is available only in Quality Companion version 3.2.1 and later.
Thanks
