Is it possible for my MP4 file be converted to 3GP?
Is it possible for my MP 4 file be converted to 3 GP? What application should I use to do this conversion so that I will be able to play the video file on my mobile phone?
Sure you can convert mp4 to 3gp. Just visit this site https://filehippo.com/ and search on the site converter like video converter or a to z converter. It's free to download, make sure the software is compatible with your computer operating system like Windows XP or windows 7.
Thank you,
Lou
Hi Jolie,
Yes, it is possible to convert your MP 4 to 3 GP media file type. To do this, you need to install an MP 4 to 3 GP converter software. There are many converter software available online for free. They will help you convert your MP 4 files to 3 GP and play it on your mobile phone without affecting the quality of the media.
You can also convert from other file types to 3 GP. Basically, it is an all-in-one tool. You can search for them online; just type in MP 4 to 3 GP converter and download it for free.
Good luck.
Almost all types of converters are available even in audio and video file formats. If you want to convert your MP4 files to 3GP format you may have to use “Cool MP4 to 3GP Converter”.
This software is easily available on following sites for download:
Hello Jolie,
Yes it is possible to convert a MP4 file to 3GP. I use Any Video Converter software to convert my files. You can convert any format file into any desirable format.
1. Install Any Video Converter.
2. Load a MP4 file from your computer.
3. Select the output profile as Mobile 3GP.
4. Press the convert now button.
Done.
Hello Jolie Angeliname,
Yes of course you can convert videos Mp4 to 3gp. And other formats to your desired formats. You can use YouTube Downloader, it has also a converter with it.
Hope this helped you!
Dear Jolie,
You can convert a mp4 file to 3gp file. Firstly you want to go Google search. Then search a converter. Its name is Format factory. After you can download it and install to your computer.
Then It will create a shortcut on your desktop. Double click it goes to the "ADD FILE" menu. Then add your file. Now go to the left side on the screen select '3GP"mode. Now go to the "Tool bar' & click the 'Start button'. Then you can convert the file.
Thank you.
There are a number of free software's available on the internet to convert Mp4 to 3GP.
I have always used "format factory" to convert any file format to another. Format Factory is a multi format media converter using which you can convert any media format to MP4/3GP/MPG/AVI/WMV/FLV/SWF.
Apart from that you can also convert the file format of any audio or image file to any require format.
Here is the list of all the supported formats by format converter.
1. Audio file: All to MP3/WMA/AMR/OGG/AAC/WAV.
2. Image file: All to JPG/BMP/PNG/TIF/ICO/GIF/TGA.
