Is it possible for PDF creator embed in program?
Hi there.  I was wondering if it is possible for a PDF creator embed in program?  I was hoping to create a PDF file from a Windows program.  I'm on a Windows Vista 64bit system.  Any help would be much appreciated.  Thanks in advance.
Answered By 0 points N/A #142900
You can use any of Microsoft Office products, to handle this, I'll share with you the steps to do it.
Let's try it with Microsoft Word :
1. Click menu File > Print, then choose cutePDF writer and hit print button.
You will be asked to located a directory to save your pdf file, select one, and hit Save.
You can also do it with another way,  just Click the Microsoft office Button on the top of menu, point the mouse on Save as menu, then choose PDF.
