Is it possible to read Arabic on PS Vita?
I recently purchased PS Vita and was wondering if it supports for Arabic language. If it is possible to read Arabic on PS Vita, then tell me. Any kind of help would be appreciated.
Hello Onam,
As of now, the Arabic languages are not supported for the Play Station Vita, but there are plans of including the Arabic languages in the future software updates. So you may just need to ensure that you PS Vita is updated more often so that when the Arabic languages are available in the software updates they will be installed.
Besides the PS Vita lacking the Arabic language, it does not support flash browser as it in YouTube and other flash supported sites. This is another update that is yet to be done in the future using the software updates.
Hope this helps.
Carl
Your question is very easy. Just to say yes or no.
And I know the answer should be yes because it is possible to read Arabic on PS Vita. Although you didn't want to know more about it, I'm giving you some additional information. Go to the link below and learn whatever you need about it:
http://softwaretopic.informer.com/how-can-i-read-arabic-on-ps-vita/
I think it will be helpful
Thanks for asking.
Hathy
Dear Onam,
As of today, there is officially no support for arabic characters in the PS OS neither for PS VITA nor for PS3
And this is strange even though the PlayStation has a huge market in Arab Countries. However, there is the possibility that an upcoming update will include support for Arabic onboard the PS Vita and PS3.
For now, however, there is no official Arabic support so you cannot view or read arabic on your PS Vita.
Keep your hopes up though.
Hi
Regarding on this issue there is another Techyv post which one will be also helpful for . Go that page and get more helpful tips to solve this problem easily.
