Is it possible to recover deleted files?
Hello Everyone,
Please help me how to recover my old files, when i was in the vacation for 5 months my laptop is in standby because i'm using another one on the vacation, i was just shock when i open my old files, it has display error on something. It is very important because i don't have a backup on it. Please help me recover my files without formatting.
Thanks, Bette
Best Answer by lee hung
Answered By 75 points N/A #121162
When it comes to recovering, I'm pretty sure that the file still there, We hopefully pray that it was not corrupted and if it is corrupted then you don't have a chances to recover those files your chances will be less. Try to use software recovery on the internet, click the program you want to recover(Video,MP3,Pictures) then the software will retrieve if your file is not damage. The other option is try to open your hard drive to other computer using enclosure. The simple steps will be removing your hard disk and check it to the other computer if the file still there. If you find it out that your file still there, then i'm sure you are having a problem with your Operating System. This is just a common steps on computer troubleshooting it's just a trial and error procedures.
Thanks,
Tony Stevenson
Answered By 10 points N/A #121164
You can try using a file recovery program, and I will recommend one called 'Recover My Files' for you. Just follow the procedure below:
  • Go to google.com and search for recover my files.
  • Click on the first search result which should take you to www.recovermyfiles.com.
  • From there, download the recovermyfiles application.
  • Install it on your computer and then launch it.
  • With the application open, locate the hard drive partition that your files are on, and then use recovermyfiles to recover all files from that partition.
  • You will choose the files that you need from the list of files that will be recovered because they will be a lot, and then save them on another partition on your computer.
Regards
Thompson Locker
Answered By 0 points N/A #121166
Recovering deleted file is possible if it isn't overwritten by other data.
This Techyv page describes some powerful softwares to recover your file.
How can I recover lost or deleted files easily?
