Last year I purchased Lenovo laptop with Lenovo OEM Windows7, and now I’m planning to purchase a Dell OptiPlex desktop.
I want to know if it is possible to reuse Lenovo OEM Windows7 for my new desktop.
Any kind of help would be appreciated.
Is it possible to reuse Lenovo OEM windows7?
Hello Nimrod
The OEM windows 7, which you got along with your Lenovo laptop, cannot be used in any other laptop or computer.
Even if you stop using your Lenovo laptop, you simply cannot use the windows in any other machine.
That OEM license belongs to the original machine. If due to any reason the computer dies, the license dies with it!
You can sell the laptop along with the OEM Windows 7 to anyone.
Advice: You should plan on buying a desktop which comes with an OEM license.
Hope this helps!
