I know that MacOS doesn't supports Windows applications but isn't there a way to run Microsoft Office 2013 on MacBook Air by means such as Wine for Linux. I'm ready to pay for the Office Suite but I want to find out how to use some of the most useful Windows applications on MacOS.
Is it possible to run MS Office 2013 on MacBook Air?
Office for MAC:
Yes, you can easily run MS office on a mac. You can’t run office 2013 on MAC but you can easily run office 2011 on mac. When we run MS office 2011 on a MAC then we get similar feature same as window. Office is easily compatible for MAC same as window. Without any interruption we can easily run MS office on a MAC.
If you are wondering why you can’t use Microsoft Office 2013 on your Mac PC, that is because, Microsoft has not released a Mac OS X version for it. But even if this is the case, there is still a chance of installing and using it on your Mac PC with the help of Boot Camp.
Try it and see if it works. An alternative to Microsoft Office 2013 for Mac is the Microsoft Office 2011. Though Microsoft Office 2013 won’t be coming to your Mac PCs, Microsoft however, has added a new feature called SkyDrive to Office 2011 for Mac. Similar to Dropbox, SkyDrive will allow you to store your Microsoft Office documents in the cloud.
With SkyDrive, you can send your files to the internet instead of storing them locally on your hard drive and with this feature you can access all your files anywhere on any computer as long as there is an internet connection.
