Is it possible to run in Windows Vista Home Basic logon script?
I searched the internet and most of the answers said its impossible to run in Windows Vista Home basic logon script. What do you think could be a workaround?
It depends on what you want to do with the log on script will you just make a network drive or printer drive map?
If your just doing network printer & drives map this can be done using a batch file command and put it in the startup folder so that it will automatically run every time you login to windows vista.
Here is an example code
Net use G:\<server><shared folder>
Doing other tasks depends on the capability of windows vista home basic since it has several limitations and may not be able to do what you need.
I hope this helps
Thank you
