I have an old Samsung galaxy SII from which I would like to copy all my contacts to my new Nokia Lumia. All contacts are about 10,000 in number and are in the phone memory. I can't have all these copied into my sim contacts given the contact limit of 250 phone contacts for the sim card. Is there another way that I can still transfer these contacts apart from the sim card?
Is it Possible to Transfer Contacts From Samsung Galaxy to Nokia Lumia??
Happy to support you!
Actually it is a quite simple task to transfer contacts from one phone to another, other than the option of copying into the sim contacts.
You can simply do it through a wired or a wireless connection with a computer or through wireless connections like Bluetooth established between the two phones. Further there are other options like using the the "Over-The-Air" technique, with the use of a tool like "Mobical" which uses the concept of cloud computing.
By using these options you can quickly & easily transfer the contacts, regardless of the great number of contacts present.
