Is it possible to turn my phone into disposable one?
I saw that 'Burner turns your iPhone into a disposable'.
How is it possible?
Is it like a onetime pen use it once and throw away?
If not, what exactly it?
How is it possible?
You need to know which company does the phone tie up. Mobile phones are usually locked on a certain company.
If its a T-Mobile, then you can get the T-Mobile Prepaid, At Prepaid and more.
If you wish to use the phone under the same carrier, just purchase a new SIM card and use the phone with prepaid.
If you need a throw-away phone number, then you are lucky because it is now available as the Burner iPhone app, from a company called Ad Hoc. A technical explanation concerning how it works is not out just yet, but using it is extremely simple. You can pay as little as $2 for the application, and then you will have a new phone number that will last you for about 20 minutes, you can use 60 texts with it or seven days.
The new digits will be used as the caller ID, and then later on you can be able to hit the burn key so as to permanently remove it from the company's servers, and then after than you can be able to get additional credits as well as a new number if you want it.
Carl
