jhonny jack
30 points
Posted on - 04/05/2013
I am running Teamviewer version one in my Windows platform. I would like to upgrade to Teamviewer version 6, yes, simply because I like growing with the technology. I have tried to upgrade the application but every time I get a message telling me that the process is not successful. How do I upgrade to the new version? Does it require that I have to uninstall the previous version before installing a new one?
Is it possible to upgrade from Teamviewer version 1 to 6?
Hello
Teamviewer 6 works perfectly fine on windows OS, Particularly compatibility with Windows 98, Windows ME, and Windows NT, Now before you download Teamviewer 6, Please closed down the Teamviewer 1, Or uninstall, If you are ok with it. Now I am sending you a link from where you can learn how to install the Teamviewer without any hustle.
https://www.teamviewer.com/en/res/pdf/first_steps_presentation_en.pdf
Thanks
Hello Jack,
Yes you have to uninstall the old version of teamviewer and install a teamviewer 6. This version has no problem and has an excellent function. You don't need to worry to uninstall and installing new software because you can make it in a short period of time. Clink this link to download teamviewer 6.
https://www.teamviewer.com/en/download/previous-versions/
