Hanadi1988
Posted on - 01/23/2013
 I don’ t have any key store or key file for that certificates. Is it possible to use an already existing certificate in Mac web server? Even if I have a key file also, is it possible to use that SSL certificate? Â
Thank you
Is it possible to use an already existing SSL certificate
Hi Hanadi1988,
If you have existing SSL certificate that's trusted CA or not yet expired. Or if you are holding a non-expired SSL certification then you can use that certification to replace the old SSL server provided with view connection server.
You can use the private key of the existing SSL in PFX format or otherwise known as PKCS#12 file format. Do not set aside the server and private key, sometimes a file extension would have been there.
Steeley
