Hi TechyV,
Is it possible to use magic jack android app? I want to install my magic jack application in an android operating system, would it be possible? But if there are some instances that it will not be applicable or compatible please let me know. I just want an accurate explanation. Hoping for your respond.
Dear Charles
I have read your question and I know that you are wondering if it is possible to use your magic jack account on your android operating system.
I would like to tell you that the magic jack application works fine on the android operating system but of course I can’t guarantee what if the program will cause any problems or not, all I can assure you is that is working properly on Android.
Now in the download section of the Android the magic jack application has not the same name, it is called Talk Free (free calls with magic jack), but it has the entire magic jack same features, you can make free calls to any magic jack numbers, US or Canadian numbers.
It is a free application and you can even use your magic jack number.
abragas
Hi Charles,
Yes it’s possible. Just download the app using Google play. Here is the Google play link:
You can use Magic Jack to call free on US and Canada. And or call Magic Jack number anywhere in the world. You just need to have an internet connection via WiFi or 4 G in order for you to make calls.
