mart cullen
10 points
Posted on - 10/19/2012
Hi
I previously uses windows 7 OS and I used other OS with Windows Virtual PC, Now I had apple branded laptop with Lion OS.
I need to know it possible to use Microsoft virtual pc for lion operating system.
Is it possible to use Microsoft virtual pc for lion operating system
There are different versions of virtual PC. For example long time ago I used Virtual PC on my Mac OS 9.
Just find the version suitable for the system that you have.
Please read carefully the installation instructions and the specifications. Here the last version Virtual PC 7.
http://www.microsoft.com/australia/office/mac/virtualpc7/default.aspx#1
Hi
I will help to download virtual pc for mac OS X Lion. The Microsoft VirtualPC was designed to run on old PowerPC architecture.
So your Mac laptop with Lion operating system will not support it.
If you want to run Microsoft Windows 7 on your Mac, then you can buy VMware Fusion or Parallels Desktop from Mac App Store.
They let you run Windows on Mac with virtualization technology.
