Is it possible to view the source code of a web page?
Yes it is possible to view the source code of any web page and it is the easiest thing I have ever known. I try to explain how to view the source code in different major browsers.
It is important when you are viewing the source code of any web page that only information and code is not processed by the server so you can view the code used to generate the result page but you cannot see the source code.
If you use Microsoft internet explorer to view the source code following steps. Open internet explorer and click to view and from the drop down Menu click ‘’Source’’, If you use Mozilla Firefox you can follow the same steps.
Hello there,
If you are using Opera, open Opera then click view. Choose Source in the drop down menu or you can just simply press Ctrl +Â F3. A new window will pop up containing the source code of the website. If you are using Google chrome, open the Google chrome browser.
Right click on the site you wish to track and select View page source. Another tab next to it will open up and will show you the source code of the web page you are browsing. You can also click the icon that looks like a page next to the wrench icon. Select Developer > View Source.
