Is it possible windows to run remote batch file?
I need to run a batch file remotely on windows. How can I execute windows run remote batch file locally? Assist.
Answered By 0 points N/A #139155
Hi Mr. Meghanjdominguez,
Yes, you can execute remote windows batch file locally sitting in front of your computer. Please follow the below steps.(Please follow the below steps in remote and local computer as well)
1.Turn on your computer with internet connection tell the remote computer too.
2.Now in your PC, please open your internet browser.
3.Type in the address bar www.ammyy.com and hit enter.
4.The page will be opened up.Look into the middle of the page.There is a green box written with start working with ammyy admin (its' free).Now click on it.
5.When you will click the application will be downloaded.
6.Download the application and open it up.It may ask for run or save file depending on browser.Click on run then yes or OK.
7.Now you will be displayed ammyy admin's remote connection box.
8.Look into the right hand side column of the wizard,you will find client id/IP option.
9.Please ask your remote computer tell him his computer ID which is written in the left hand side of the ammyy admin's remote connection box.
10.Please enter remote computers ID in your local computer's client ID/IP option and click OK.
11.Now your remote computer will be asked for to accept your request.Tell them to click on accept.
Now you can see your remote computer in your local computer and whatever batch file you want to run in the remote computer,you can do it.
