Hi TechyV users and friends,
I have been wondering that if it's possible to work Nitro pdf two monitors. Like two documents in parallel type of view. My question is, is it possible to do that? If yes, How can I do it? What are the steps opening a two documents in one screen. Any help would be appreciated. Thanks and have a good day
Desiraealexa
Is it possible to work Nitro PDF on two monitors?
Hi Desiraealexa,
Yeah! It’s possible to view two documents in parallel type. Just open two documents in Nitro Pro7. Then right click on a document tab. You’ll have to select either new horizontal tab or new vertical tab. Now you can easily work in two documents at a time.
Good Luck.
Hello,Desiraealexa
Hope you are fine.
You can open not only two but also more documents in parallel view.
At the first open your desired documents (two or more ) in Nitro Pro 7
Do any of the following:
Drag and drop a document tab away from the tab bar
Or
Right-click on a document tab
After that in the menu, select any of the following:
New Horizontal Tab Group:Displays the documents in a horizontally parallel view
New Vertical Tab Group:Displays the documents in a vertically parallel view
If you desire to create more parallel views, then you have to open another PDFÂ document, and repeat steps 2 and 3.
A video can teach you better.
Click the link to see the video
Best of luck!! Â Â Â Â Â Â Â Â Â
Hello Desiraealexa,
I have included a few tips below to help you do more with PDF files, and save some time..
Confirm your version and licensing details.
People ask what version they have installed or the status of their license. Whether you’re looking for documentation, lodging a support case, or checking for upgrades – it’s a handy thing to know. Follow these steps,
StartNitro Pro
Go to Help
Select About
Here you will come to know what version you are using.
Here is how to copy one picture from a PDF to another PDF.
Click the edit tool
Right click on your image
Copy it
And paste it on the document you want.
Choose Copy Text
Choose text in question
Right click on it
Select different options required
Here is how to open two documents on single monitor,
Just open documents you want and resize them to fit on the monitor.
Hope this helps you.
Thanks,
