Jamin Ywain
60 points
Posted on - 09/25/2012
Hi guys,
I have no idea about the error message. It is relating to my Premiere Pro. Look at the screenshot below.
Do you understand the error?
Please help me to solve the error.
Premier Pro Debug Event
Premiere Pro has encountered an error.
[….SrcAESupportAEInData.cpp-712]
Hello.
After a quick research I found some ways for your problem.
First of all check whether graphic driver is up to date.
This problem mainly arises due to out-dated graphic drivers.
If the problem still persists you need to clean everything related to premier pro by using adobe cleaning tool.
To know more about adobe cleaning tool and to download click on the link below.
https://helpx.adobe.com/creative-cloud/kb/cc-cleaner-tool-installation-problems.html
Once you clean everything you need to again reinstall premier pro.
Thank you.
