Is it required to create backup before upgrading library to iTunes Plus?
There is no need to create back up files when you upgrade your Library to iTunes Plus. ITunes actually replaces your original files, but you will be given an option to save your files to your computer or to delete them at the time of the downloading process.
iTunes is very famous music enjoying software. Anyone can easily find music and download them from the tone store anytime. For its easy using interface, it has gained much popularity over the world. iTunes Plus is that you have to buy/bought a licensed copy of iTunes to get full service. So you'll have to just enter registration code. No uninstallation is required. If you want to uninstall, then just you will need to backup your music library. Otherwise, not.
