Loczin
Posted on - 12/05/2011
Hello Techyv,
I don’t know what happen after my kid used my PC. Something happen in my ICQ that can’t start immediately. I tried to reinstall the software and check the Ethernet connection but same error displays in the screen.
I really appreciated all given solution for this matter.
Thanks techyv!
Error display:
ICQ
You have disabled direct communication with previous (less secure) clients
OK
It seems can’t used the ICQ now
Hi loczin.
It’s a bad for you. Well i have solution for you.
Step1. You should take removing ICQ chat soft from your PC. Which you can from Start Menu? Control panel. Add or remove programs if it is Windows xp, if it is Windows 7 then uninstall program. Then remove from your system permanently.
step2. Scan your whole system and restart the computer.
step3. You will get install then from new. Log in by user ID and Password.
If it will not work then direct go the website and log in home page, it may really solve your problem.
Regards.
Your friend
